C programming, function returning a garbage value
Discussion in 'Microcontrollers, Programming and IoT' started by Luke Vassallo, Mar 26, 2015.
  1. Luke Vassallo
    Luke Vassallo
    33
    4
    Dec 10, 2014
    Hello,
    I am creating a program that will check for a number if a number is prime or not. However the function is returning a garbage number when I use local variables.(works fine with global though)
    the code looks fine to me however I can't understand what's going wrong.
    this is the function
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Can you post the section of code that calls the function as well?
  3. Luke Vassallo
    Luke Vassallo
    33
    4
    Dec 10, 2014
    I fixed the problem. It was expecting that after the function is executed it's value will be changed to either a 1 or a 0. But then I called the function to execute the code and use the returned value immediately.
    I was thinking of it the wrong way, it actually returns a value and not change the function's value itself
    Gryd3 likes this.
