N
N_Cook
Goes into protect mode at switch on.
Useful info and schema on these G class amps
http://www.reptips.dk/Reptips/CAUDIO.pdf
as well as schema only, on e-service
One smps supplies both amps and 4 rails, each rail supplies both ch, I've
cut the "overdrive" rails temporarily and running on +/- 60V.
Output has about +18V on ch1 for about a second before dropping down to 0,
so o/p DCsense line to the PIC tells it to go into protect, of whole amp.
With 15R load then op jump is to about 10V. The other ch2 is fine , no more
than 0.5V on output loaded or not.
Same 2 (4 in full operation) rails supply both amps. All electrolytics check
out ok. Problem fault tracing is 3/4 of the active in this amp shows the
same 18V or so jump at power-up.
Disabling the protect line, so the amp powers up, shows nothing amiss after
2 seconds, on all main transistors, running at +/-25 V rails anyway. I will
repeat this now at +/-60 V but as no 1 to 1 correspondence of device
numbering or posistioning between ch1 and ch2 a bit awkward and I don't
expect to see any substantial DC differences as has settled down after the
first couple of seconds. How to zero-in to the problem device . Nothing
untoward at the pa input but I will tie to ground the next time of powering
up just to confirm.
up just to confirm.
