Thanks for the replies.
Did some testing and checking to see if i could see anything that might be obstructing the gears and I don't see anything. I tall looks good. if i open it up and turn the threaded shaft i don't notice anything out of the ordinary from one direction to another. It is not easy to move then then when I am working against the idle motor i would expect this.
@73 s de Edd. Should i use different wire to test with? I have a bunch of varying guage wire solid and stranded if would be better. Also, to measure the voltage I am still a bit confused. On my multimeter i am taking the red cable and moving it over to the other open slot on the multimeter that says 10A - "10A for 30 sec Max every 15 min". Also, on the multimeter what do i turn the dial to? From there what am i touching the red wire to and what am i touching the black wire to specifically to get you these measurements?
Is it possible to just replace the motor with a same brand or one similar perhaps? It feels to me like there is something going on with it is what your guys gut at this point is thinking too?
