Buzzing Makita DC1414 F charger
Cirkit
Oct 28, 2015
155
Oct 28, 2015
155
I have the above Makita charger which is buzzing with a variable frequency when the green LED flashes.
I have tried prodding the transformer and various components but the buzzing doesn't stop.
I don't want to start replacing capacitors on the chance that may cure the buzzing.
Attached are photos and a video showing the buzzing can be downloaded from this link:
https://ufile.io/v78dr3o2
Any suggestions on where I should start looking?
Thanks.
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
Hi CirKit,
The free (slow) D/L doesn’t work.
Can you describe the buzz?.
Is it only when the LED flashes?.
Is it definitely a buzz rather than a high pitch tone?
Martin
Harald Kapp
13,738
13,738
Download worked for me.
It is a medium to high pitched sound (similar to an electric razor, but not so loud). The frequency changes with the blinking of the LED: LED on -> frequency high, LED off, frequency low. Notable peaks are around 4 kHz and 6 kHz:
Martaine2005
May 12, 2015
4,953
May 12, 2015
4,953
It sounds like the caps aren’t doing their job. Given the stresses these caps go through in SMPS, they are also the first components to fail.
I would replace them as a matter of course.
Martin
Cirkit
Oct 28, 2015
155
Oct 28, 2015
155
Thanks for uploading the spectrum @Harald Kapp.
@Martaine2005 do you have any suggestions which capacitors I should replace? Is it likely to be the main filter capacitor?
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
The mains capacitor could cause hum.
The output capacitor could cause screeming (high frequency noise), when the ESR is going up.
Bertus
bertus
Nov 8, 2019
3,330
Nov 8, 2019
3,330
Hello,
When you change the fourrier size and look at the spectrum, the 100 Hz is good visible:
You will also see signals at 4000, 8000 and 12000 Hz.
Bertus
