Buzzer Help
Discussion in 'General Electronics Discussion' started by Rajinder, Aug 1, 2016.
  1. Rajinder
    Rajinder
    529
    9
    Jan 30, 2016
    I have attached a copy of the voltge seen on a piezo buzzer. I need to ckamp this to 3V3 and then detect the edges of the waverform at 1.17 secs, feed this into a microcontroller and measure the time between pulses.
    I was thinking of clamping the wavefor which is 30V by using a suitable resistor and zener diode at 3V3 or around that figure. This will remove the negative going part of the waveform. Then feed this into a differentiator to detect the positive edges and feet into a microcontroller I/O pin.
    If the piezo was say operating at 20mA (for example), to calculate the series resistor with the zener is it simply a case of 30-3v3/20mA. Then ensuring power requirements can be satisfied i.e. wattage of resistor.
    would this be then suitable to connect to the differentiator circuit? or would i need some further signal cleaning after the differentiator stage?
    any help would be appreciated.
    Best regards,
    raj
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    It must be the water draining away some of the magnetic field :)
  3. Alec_t
    Alec_t
    2,940
    799
    Jul 7, 2015
    Not unless you want 20mA flowing through the zener. The buzzer current is irrelevant. Make R=(30-3.3)/Izener. A zener current of just a few mA should be enough.
  4. Rajinder
    Rajinder
    529
    9
    Jan 30, 2016
    Thanks. If I put 5mA through the sender, that should be ok? Would there be a problem with the differentiator part of the circuit, just to detect edges or is there a better way to achieve this?
    Best regards,
    Raj
  5. Alec_t
    Alec_t
    2,940
    799
    Jul 7, 2015
    Personally I'd use a CMOS Schmitt trigger, instead of a differentiator, to get sharp pulse edges.
