Hi everyone, I need help as I am trying to make a circuit for a buzz wire game, the type where you need a steady hand as you move the loop along a wire pathway trying hard not to touch the wire, setting the buzzer off.
The big difference with my one is that I need it to be wireless! I don’t want the hand held loop to have a wire connected to it, it will just be a metal ring held in the hand of the user. The circuit must run on batteries, so no high voltage, say around 3V to 6V (or maybe slightly higher)
There are only 2 ways I can see of doing this:
1. Using a very sensitive circuit which relies on the user creating a ground/Earth by touching it, although having such low voltage in the circuit this may be difficult, or
2. The wire that the loop moves across would have to be made of something really intricate, which has lots of small copper lines on it, so that when the loop touches it, it will complete the circuit?
Any ideas or suggestions for another method or solving this problem would be greatly appreciated!
Many Thanks
Inspire
Many Thanks
Inspire
