button on/off
Discussion in 'General Electronics Discussion' started by tom356, Feb 15, 2013.
  1. tom356
    tom356
    Feb 15, 2013
    Hi
    I been searching for days for a on/off button stands alone in a case..
    I have attached a picture of a sample it dont have to be the same just
    a button that will you can just hook up wires to in its own box..
    Like a door bell box button, but push on/off
    If anyone know were i can get them please leave a link..
    thank you ,,tom
  2. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    do you want just a switch?
    you say its push on/off does that mean you push once to turn on then push again to turn off?
    is this for foot or hand?
    for push on push off try these
    http://www.jaycar.com.au/productView.asp?ID=SP0718
    http://www.jaycar.com.au/productView.asp?ID=SP0656
    for foot switch try this push on push off
    http://www.jaycar.com.au/productView.asp?ID=SP0764
    for momentary
    http://www.jaycar.com.au/productView.asp?ID=SP0716
    if youwant these already n boxes you could find them or you could spend 20 minutes and make a box yourself saving a bit of cash.
    it all depends on the voltage, current and size you are looking for
  3. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    It would be helpful if you told us where you're located. There's an option for this in your profile settings and it's there for a reason.
    As donkey says, you need to describe what you want. You can get push-on/push-off and momentary (ON while button is held in); both types are readily available from electronic component suppliers and you can build them into an old pill container or similar. Many suppliers have prepackaged ones as well.
