N
N_Cook
Where they use 12V battery and inverter to synthesised mains and then
SMPS type amp. So the dirty-mains filter caps on the mains side have no
ground reference and all the grounded points including guitar metal
parts rise to some highish voltage until someone touches them and
discharges the caps.
Ignore it as not a personal safety issue unless the psychological shock
leads to problems.? Is there a work around, ie metal plate under the
amp, connected to an amp earth point and a cup of water on the
soil/pavement under the metal plate?
ps seventh attempt via e-S/Thuynderbird to s.e.r, uk.test is ok
