M
[email protected]
A friend gave me a little yellow toroid (ferrite?) with a winding
around it, that he had butchered from some non-working computer part.
I unwound the (thick!) wire, re-wound it with 10 turns of primary, and
50 turns of secondary.
I then built an astable multivibrator switching at 70 kHz, running off
3VDC, switching a TIP31, hoping to get a x5 multiplication of the
voltage.
I got exactly 0 volts out of the secondary.
Why is this?
Is there a minimum voltage requirement for flyback transformers?
Similar effect with 6VDC on the primary side.
At first I thought the yellow ring may be made of plastic, but a
neodymium magnet happily picks up the toroid...
I'm using an NTE587 fast switching diode on the secondary side.
Michael
voltage.
Why is this?
Michael
