Building wiring circuit keeps tripping breaker.
Discussion in 'General Electronics Discussion' started by mrmarcdee, Feb 19, 2015.
Thread Status:
Not open for further replies.
  1. mrmarcdee
    mrmarcdee
    21
    Dec 16, 2014
    Not sure if this fits in exactly with the theme of this forum, but this is where I already have an account, so I'm hoping it'll work out.
    At my workplace we have two bathrooms on the same circuit. This circuit breaker keeps getting tripped a lot recently. Each bathroom has one overhead light, one bathroom exhaust fan, one Xcelerator hand drier, and a fan-forced wall mounted heater. I replaced the heater in one bathroom approximately a year ago, and I replaced the heater in the second bathroom a few months ago. The tripping started after replacing the second heater, which I noticed was rated at a higher voltage (and presumably amperage, but not sure). It is a 20 amp breaker switch. Both heaters are the same and they say 120 volt and 12.6,9.4,6.3,3.1 amps (1500,1125,750,375 watts). I assume the different amperage ratings are for the different settings on the heater, it has a knob that goes up to 6.
    Of course easy math shows that two 12.6 amp heaters are more than the 20 amp breaker. I tried purposely tripping the breaker as a test, by turning both heaters to max, both lights and fans on, and triggering both hand driers at once, but everything stayed on during that test.
    That's about all I know. So I'm just looking for some advice on how I could fix this.
    Marc
  2. davenn
    davenn Moderator
    13,799
    1,939
    hi Marc
    Tho you may get reasonable info on something like that on a forum
    it would be very difficult to give quality info due to not being onsite to see and test the actual fault
    This really requires you to employ a qualified electrician to sort out something like this :)
    cheers
    Tha fios agaibh and KrisBlueNZ like this.
  3. BobK
    7,682
    1,688
    Put in another circuit.
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Is the breaker an RCD type Marc?
    Adam
  5. Externet
    Externet
    759
    165
    Aug 24, 2009
    Disconnect/disable any item that was in use at the moment of breaker tripping; preferable the suspect new hand dryer to confirm if the behavior persists or not.
    If power disruption persists, That dryer circuit can be assumed healthy.
    Move the wiring in the breaker box to another equal-rating breaker and evaluate for a while.
  6. Tha fios agaibh
    Tha fios agaibh
    2,143
    724
    Aug 11, 2014
    Bob's right, your circuits are overloaded.
    Even two 20a breakers is probably not enough.
    Hire an electrician to make it right. (Gfci protection and applicable codes.)
  7. davenn
    davenn Moderator
    13,799
    1,939
    which is what I suggested a number of posts ago
    for everyone's safety, this thread is closed
Thread Status:
