Al said:
When I was a kid, I magnetized my screwdrivers by placing them in a
solonoid and sparking a 6V lantern battery across the terminals of the
coil. Made them strong enough to pick up nails and screws.
Al
Yuppp that's almost what I was going to suggest. My thought was to remove
the magnet and wind as many turns of 16 or 18 gauge wire around it as will
fit. Then get a high current power supply, one that can put out several
amps of current at around 5 volts or so. Apply the current to the winding
for a few seconds and see if it increased the strength. If the strength
seems lower, reverse the polarity of the power supply connection and try
again.
Don't know how long to suggest that the current be applied.. A word of
caution here... be sure that the power supply you use has current limiting,
or at least some form of short circuit protection. The reason being that
the winding will present a very low resistance load and could damage an
unprotected power supply.
Cheers!!!
Tweetldee
Tweetldee at att dot net (Just subsitute the appropriate characters in the
address)
Never take a laxative and a sleeping pill at the same time!!
