amdx said:
Hi Guys,
I'm interested in a discussion about building a high sensitivity set of
headphones.
The intended use would with a crystal radio.
The usual thing is to find an old set of Brandes headphones with 2000 ohms
DC resistance.
It seems like the collective intellect here could design or modify
existing headphones
to provide a better impedance match and increase the sensitivity of
headphones.
Maybe there are some better materials now then there were 80 years ago.
Any ideas about the ideal characteristics for a set of crystal radio
headphones?
You want an infinitely high input impedance and no shunt capacitance.
The old method was to use the finest possible wire, and as many turns of
it as possible. This results in some design issues; because your coil is
now extremely massy, you can't use a moving coil transducer design and
get good high frequency response. So most of those high-Z headphones were
variable reluctance types.
Another old method is to use a piezoelectric transducer. I think that is
still a viable method, maybe using some of the Motorola piezo horn elements.
The easiest way to do it today would be to use a modern low-z headphone
with a JFET follower in front of it. Gives you as high an input Z as you
would ever want. But, really, that would be cheating, wouldn't it?
--scott
