Building a serial remote
Discussion in 'Electronic Basics' started by Darren, Jan 8, 2005.
  1. Darren
    Darren Guest
    I'm trying to build a remote control that works over serial.
    I've never tried anything like this before so I don't know how to go about
    it.
    I know I need a 232 driver chip to convert the voltage from a 5v PIC output
    to the 12v serial link.
    What I really need is a circuit diagram and advice on which PIC to use to
    create a serial bit stream and if possible some code to do it.
    It needs to have about 13 buttons on it, and if possible a small (6 or 8 by
    1) backlit LCD to receive text, the backlight should turn off after about
    10 seconds, and there should be a switch to turn the remote off completely
    to stop accidental button pressses.
    There seems to be so many programmable chips that have all sorts of options
    but I don't know which is best.
    Darren
  2. If you're going to use a PIC, then look at the 16F628 or 16F88. These
    are the "generic" 18pin parts, the 88 contains real ADC's whereas the
    628 contains only comparators. The 16F876 and 16F877 are nice 28 and 40
    pin parts respectively.
    If you are just starting out with PICs, you may wish to learn the
    18F452. It is a 16bit instruction word core with many enhancements over
    the 16F series.
