Building a circuit on a bread board
Discussion in 'General Electronics Discussion' started by lucianthelight, Apr 18, 2017.
  1. lucianthelight
    lucianthelight
    Apr 18, 2017
    I have some questions about building a circuit on a bread board. Or more specifically correctly connecting said circuit to a powersupply/ ground.
    The example circuit we where given can be found with the attached files.
    As power supply we use the HAMEG HM7042-5 (picture can also be found in the attached files). So my questions are:
    - Do I have to connect the ground on the left separately or can I just use the ground of the supply V1?
    - We need to measure the outgoing voltage Vuit, to do this I presume I need to connect the wire to a ground and attach a voltage meter in parallel.
    - If this is correct can I use the same ground of a power supply such as the one of V1?
    Thanks in advance
  2. (*steve*)
    25,505
    2,849
    I can't quite follow your question, but I can follow the circuit.
    The ground symbols are common, but only two power supplies have a direct connection to it.
    Beware of having outputs of your power supply grounded. I presume the outputs are floating.
  3. ag273n
    ag273n
    74
    4
    Nov 24, 2016
    if you have two power sources in one circuit, yes, you need to connect them in one same ground
    Hope this answers your doubts
  4. (*steve*)
    25,505
    2,849
    Did you look at the circuit?
  5. ag273n
    ag273n
    74
    4
    Nov 24, 2016
    i was hopping to answer this question... seemed to me he had doubts whether two grounds are ok in one circuit..
  6. (*steve*)
    25,505
    2,849
    Yeah, but there are three power sources in that circuit and certain interpretations of...
    ...will yield bad results.
