Buhl overhead projector focus adjustments
Discussion in 'Electronic Repair' started by Lenny, Oct 28, 2004.
  1. Lenny
    Lenny Guest
    I have gotten in a number of Buhl model 80 and 80/14 overheads that
    will not focus properly for the entire screen. Either they're good
    three quarters of the way down and then the focus starts dropping off
    or the image is good three quarters up or its one side good and the
    last 10% on the side perhaps is bad, or its one or more corners, etc.
    I have been told that any misalignment in the optics will cause this
    but looking at these units it is difficult to see where anything has
    changed. The lenses don't appear to be warped and all look slightly
    concave as they should. It is possible to shift the lightbox from side
    to side or tilt it, ( I haven't done this yet) but I'm not certain how
    to draw a relationship between what is out of focus and as a result
    what to adjust. I have a transparency with symetrical lines of one
    letter on it. I'm told that this focus process can be a real pain so I
    don't want to make it worse than it already is. Does anyone have any
    experience with this? Thanks, Lenny Stein, Barlen Electronics
  2. jakdedert
    jakdedert Guest
    Overheads are notorious for focus problems. Most can be resolved by proper
    placement of the unit relative to the screen. They were never meant to be
    hi-res. Make sure your screen is perpendicular to the projector and
    perfectly flat. Tilting the screen can alleviate 'keystone' issues. The
    projector needs to be set exactly in the center of the screen horizontally.
    Move it back and forth, or measure the diagonal from each corner of the
    screen to the center of the projector lense.
    jak
