but are they actually practical to use in real life and where would you use them?. Wouldnt it be easier and more effiecient to use the correct size voltage to begin with?
Hi Jon,
welcome to EP
you just mentioned 1 of 2 types of regulators. The other is a boost regulator
They are used in just about every piece of electronics imaginable
TV, DVD, VCR, computer, cameras, mobile phones etc etc
Wouldn't it be easier and more efficient to use the correct size voltage to begin with?
often multiple power rails are needed in a bit of gear, so a different regulator is used to supply a stabilised voltage for each power rail there is
eg ... the main DC voltage out of the rectifier may be say, 24VDC, and we need several down conversions to supply an 18VDC, 12VDC and say a 5VDC rails
so there is 3 buck converters in just that one bit of gear
ohhh and I moved the thread to somewhere more appropriate
