Jamie Morken
I am looking for some high frequency (1MHz+) step down buck switcher
chips that can handle an input voltage of at least 7.4V and at least
500mA output current. The Texas Instruments TPS623xx 500mA/3MHz
switchers are perfect but they are only rated at 6Volts input max! I am
sure they could take 7.4V but I would rather not risk this I need to
generate 5V, 3.3V and several other lower voltages from the 7.4V (two
lithium batteries in series). This is a portable application, so power
is an issue or I would just use a linear regulator to generate 6V from
the 7.4V input.
cheers,
Jamie Morken
the 7.4V input.
cheers,
Jamie Morken
