Buck Converter stability
Discussion in 'Electronic Design' started by Sumeet, Oct 14, 2003.
  1. Sumeet
    Sumeet Guest
    My doubt is related to the solution using low ESR ceramic caps for
    buck converter stability proposed in this Maxim app note.
    http://www.maxim-ic.com/appnotes.cfm/appnote_number/1121/ln/en
    I cant figure out how they have arrived at the relations for R1 and
    Cff. Cff I can probably solve, considering a constant current charging
    it through R1 during the duty ON cycle and assuming some value of
    ripple reqd at the feedback node.
    but it appears as though they divide the vripple(p-p) reqd at the
    feedback point by 2 before they apply this charging equation. I dont
    understand this. also I dont understand the statements made about load
    transient and its relation to the size of capacitor (Cff) as also why
    we need to match the inductor time constant with R1 Cff.
    Can anyone throw more light on this please ?
    thanks
    Sumeet
  2. Genome
    Genome Guest
    You are not alone.
    If this is all Maxim are prepared to say about the thing, your above link
    and the data sheet, then I would recommend that you tell them to go get
    stuffed and DO NOT use it.
    On the other hand, being forced to read between the lines and think a bit
    deeper (something that should not be necessary!!!) This looks like a
    hysteretic voltage mode controller with a bit of added arse end.
    For fun you might play with
    http://www.transim.com/champion/Tutorial.html
    and click on item 4) under Control Strategies. Use my 'not' e-mail of
    to log in. Otherwise register using a bogus load of
    gibberish. You should get to play with a simulator model of a similar
    controller. Won't tell you what you want to know but it might begin to make
    sense as to what's happening.
    At which point I'm going to stop thinking about it. Ideally you want to find
    out some information for stability analysis of such things..... As they say,
    Google is your friend.
    Then again Maxim should be doing this.....
    DNA
  3. Active8
    Active8 Guest
    hi:
    do you and Watt Sun travel together or something. visit the group
    according to the phase of the moon, maybe? :) i haven't seen any posts
    from either of you in a while and here you both are all of a sudden.
    brs,
    mike
