Buck-Boost Inverting Power Supply
Discussion in 'Power Electronics' started by The Hammer, Jan 25, 2016.
  1. The Hammer
    The Hammer
    164
    Sep 17, 2013
    I'm looking at creating a power supply using a UC2845BD1R2G from ON Semiconductor to create a stable 12V 10A capable power source from inside a vehicle.
    The intent is to power 6 separate LED strips inside a vehicle, and down convert again using either an LDO, or a buck converter for use by an MCU and possibly USB charge ports.
    My guess would be this should work fine, but I am just beginning with power supplies. I've read the datasheet for the most part, and it seems like it's definitely plausible. I had some questions though..
    Is there a more common chip that might be easier to work with than this? Are there any preferred "caclulators" to use when calculating the needed inductor/capacitor specs? I could do the math myself on these, but still like guides as it's my first time.
    Datasheet:
    http://www.onsemi.com/pub_link/Collateral/UC3844B-D.PDF
  2. BobK
    7,664
    1,678
    What is the input power? Most vehicles already have 12V or 24V power.
  3. The Hammer
    The Hammer
    164
    Sep 17, 2013
    12V, so atypical voltage will be about 13.6V.
  4. BobK
    7,664
    1,678
    So why do you need a buck / boost converter to get 12V?
  5. The Hammer
    The Hammer
    164
    Sep 17, 2013
    There is tolerance in most RGB LED strips to allow for common voltage changes in a vehicle despite them having an optimal/"required" voltage of 12V, but in certain setups/circumstances there may not be enough tolerance. I am developing a spectrum analyzer/N channel MOSFET PWM MCU board that might encourage people with uncommon audio/electrical systems to use this. Therefore, I want to build a controlled 12V PWM system.
    For instance, in a friends vehicle with a custom audio solution, dual battery system, and an aftermarket rebuilt alternator he hovers around 15.2V typically.
