Buck-Boost grounding question
Discussion in 'Electronics Homework Help' started by avihai, Mar 11, 2014.
  1. avihai
    avihai
    Mar 11, 2014
    Hi
    I was asked the following question:
    The output's ground of a buck-boost converter was connected to the same ground as the input.
    Will the circuit work or will it damage any component?
    I didn't find any clues...
    Thanks for answering :)
  2. Harald Kapp
    11,446
    2,628
    Hello and welcome to the forum.
    The answer is: input and output of the buck-boost converter have to have a common ground. It will not work otherwise.
  3. avihai
    avihai
    Mar 11, 2014
    Thank you
