brushless dc printer motor
Discussion in 'Sensors and Actuators' started by engineeredgarden, Oct 15, 2010.
  1. engineeredgarden
    engineeredgarden
    8
    Sep 30, 2010
    I'm wanting to reduce the speed of a brushless dc printer motor, and was wondering what my options were. I know that a resistor in series with the motor would reduce the current, but would it do anything to the speed?
  2. shrtrnd
    shrtrnd
    3,804
    507
    Jan 15, 2010
    Yes, you would drop some of the voltage presently running the motor, across the resistor, slowing the motor speed.
    BE CAREFUL of the value and wattage of the resistor. I don't know what voltage your motor is running at, or the current to drive it. Too much current through the resistor, and if the wattage isn't right, you'll burn up the resistor. Wrong value of resistor, and you might starve the motor for the current necessary to drive it, causing it to overheat.
    When you do this, just leave the compartment open, and touch the resistor and motor once in a while, to make sure something doesn't rapidly overheat, if you guessed wrong.
    Of course, you COULD give us the information off the motor faceplate, Voltage, amperage, anything else useful. And then one of us can tell you more accurately what
    resistor value and wattage to use.
