Brushless DC Motor controlled by CAN BUS
Discussion in 'General Electronics Discussion' started by InquiringMind, Feb 27, 2018.
  1. InquiringMind
    InquiringMind
    Feb 26, 2018
    I'm updating an old fixture and programming using a CAN BUS on a PLC controller. My motor is already enabled and functioning with the old software. I'm measuring torque. Currently the torque sensor gets a reading and sets to zero for a 'tare.' later it takes the measured torque data and gives me a value... but the starting position is different every time. The motor has a built in encoder, with a homing feature, but I would have to change the motor firmware and enable the I/O pins so I can access the encoder. I'm wondering it there's a mathematical way to save the original tare position and revert back to that as a starting point, every time I run a test. ...just because it seems like less work to keep the current firmware.
    I already made a statement that basically tells the system that the torque is 0Nm at 0volts, but that isn't angular position.
    Any help would be appreciated. Thanks!
