S
Sam Goldwasser
So this one I'm looking at then doesn't exist? It clearly says
"Brushless Alternator" and there are clearly no brushes or slip rings,
just as there clearly *are* windings rather than permanent magnets on
the rotor. It's starting to sound like a magic trick.
You've pretty much described it. The two pole armature gets current
induced in it by rotating inside the stator and that is made to be DC
by the diode or more likely, diodes. That then acts like the permanent
magnet rotating inside a stationary magnetic field. There doesn't need
to be a smoothing cap inside to make it pure DC. I'm not going to claim
any knowledge of the details but the scheme certainly seems plausible and
with care in designing the magnetic components seems like it should work
quite well.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
