T
Thor
I have a JVC AV-27230 that of late has started to turn on rather bright, it goes
down to less but still too bright later(unknow time , maybe 10-20 minutes or
so).
I have the brightness control set near minimum, same for picture slider on the
on screen controls.
When the set is initially turned on there are also a set(2) of dashed horizontal
lines almost all the way across the very top of the screen, these vary in color
from nearly white to a yellow green. These lines across the screen eventually
settle down to two dashes single line in the upper left corner.
The high brightness is there when the TV is set to a blank input but the
horizontal lines are not. A blank input is Video1 and I have nothing connected
to that.
Same high brightness when playing a dvd along with the horizontal lines, Video3
input.
After the "warm up" the horizontal lines shorten to two or three short segmented
dashes and are only about one scan line thick, but not across the entire top of
the screen. These line sit in the upper left corner and change colors from time
to time. As I said I have the brightness slider almost all the way down, where
it shouldn't have to be. I thought it was data coming from the cable but that is
wrong if I have the same problem when looking at a different input.
With my crappy description does any one have any idea of where to look for what
is going wrong with the set? A cap going bad maybe? I don't have a schem to this
TV.
BTW, the sound is ok, it /may/ be getting louder but I am not positive on this.
With that added it sounds like something in the power supply but I don't know
what.
Ask if you need more or better info.
Thanks for any help.
Thor
so).
on screen controls.
to that.
input.
TV.
what.
Thor
