I have an old Toshiba Satellite A10 that it's become a bit of a mission to keep alive.
It has a manual volume wheel which has been damaged and I'm pretty sure I can bypass it by soldering across the contacts.
I'm a total novice and would like a little advice from someone more experienced before I start diving in.
The damaged wheel had a disk on the underside that made contact across 5 connectors, these are marked where they join the board as 1 to 5.
Instinct tells me to bridge 1 and 5 to 'fix' the volume at the maximum but this is just a guess. I'm also unsure whether to just join these two or all of them, 1, 2, 3, 4, 5.
It's proving impossible to get a photo of the part so I've drawn it and tried to scan the contact from the wheel.
Any advice would be much appreciated.
