Breakable/makeable IDC header connector, any knowledge?
Discussion in 'Electronic Repair' started by N_Cook, Aug 25, 2009.
  1. N_Cook
    N_Cook Guest
    Maker etc?
    On a 2006 German Dynacord mixer amp. I've not seem them before, no name on
    the exposed parts of the connector. 0.1 inch pitch ribbon.
    http://home.graffiti.net/diverse:graffiti.net/idc_header.jpg
    views of connectors , same, both ends of the ribbon for photoing
    convenience. top as found, pcb part, ribbon part internals
    Black end pieces are just locators and for polarising,different
    sizes/recesses, not gripping the white bits. Locking is done internally
    somehow. Anyone know the professional way of unmaking these connectors? you
    do not umake the second IDC connection, per pin, in the process of
    separating.
    I ended up using a knife blade and then jeweller's screwdriver to get
    purchase between pcb and white part that goes down to pcb level, lacquer
    damage can be seen in middle view. Perhaps a dentists sickle probe as a
    lever into the small holes along the white part edge.
