Bread board
Discussion in 'General Electronics Discussion' started by Mattblack, May 8, 2015.
  1. Mattblack
    Mattblack
    4
    May 7, 2015
    Please can someone explain why this wont work :(
  2. jarvis2.0
    jarvis2.0
    10
    Apr 29, 2015
    can you specify how much current the led can handle?
  3. Mattblack
    Mattblack
    4
    May 7, 2015
    5v
  4. davenn
    davenn Moderator
    13,940
    1,984
    QUOTE="jarvis2.0, post: 1650457, member: 39807"]can you specify how much current the led can handle?[/QUOTE]
    5V isn't current
    if it is a standard LED it will be rated at ~ 20mA
    the 1k resistor would be OK for a start with the LED
    make sure the LED is the correct way round
    how about labelling your parts ... particularly the transistor type
    first major fault is that you have the +9V bypassing the resistor and LDR and going straight to the base of the transistor
    you may well have damaged the transistor
    remove that jumper off the top of the resistor and place it between the transistor base and the connection point between the resistor and the LDR
  5. Mattblack
    Mattblack
    4
    May 7, 2015
    Awesome thank you!
