John Devereux
I am looking for some specialised "Bottom entry" connectors suitable for
circular pins.
You can get "bottom entry" or "pass through" socket connectors that sit on top
of your PCB, where the mating pins pass through holes in the board. So
you have:
.. X
.. ||X|| Connector, SMT preferred
.. ||X||
..==================X========== PCB
.. X
.. X
.. X
.. ===== Pin
There are lots available for 0.1" and 2.0mm pitch square pin headers,
designed for 0.025" or 0.5mm square pins.
Does anyone know of anything like this suitable for four round pins?
Ideally for a larger diameter than the 0.025". A wider pitch would be
good too, or single pin types I can place where I want.
circular pins.
you have:
.. X
.. ||X||
.. X
.. X
.. X
.. ===== Pin
