Somethingrandom
- Jan 20, 2014
- 22
- Joined
- Jan 20, 2014
- Messages
- 22
Afternoon Gents/Ladies
My washing machine kicked the bucket a few days ago. For the last few months it's been stopping randomly during various cycles, I have been having to turn it back on a resume the wash. It wasnt stopping in the same place and there was no pattern. Now it's refusing to turn on at all. There's no indication of anything when I turn it on, no lights, no sounds when i press the buttons, nothing at all. I spoke briefly to a repairman who has said it's probably the mainboard and that's going to be an expensive repair. I decided to open the machine up and take a look at the mainboard, there are two PCBs, mainboard and LCD display board. Examined both, found some soot build up on the mainboard around one diode's cathode was black. Also a resistor that looked like it had a fracture running down it's length. Resisistor measured infinite resistance. Took the board to a local electronics store and indicated that i wanted to replace these two components. I was given a GW418-1N4007 to replace the GP10T-1014A diode and a 220ohm resistor to replace a 200ohm one. The shop guy said a 20 ohm difference was nothing and that the resistor was just running to ground anyway so no problem. I swapped these on the board and turned on the machine. The LCD lit up, awesome... and the replaced resistor lit up... and burnt out. I killed the power. Not sure if the components I was given were suitable.
Here's the resistor, original on top. https://www.dropbox.com/s/b3zxmi0cp91qhwv/image1.JPG?dl=0
Here's the replaced one burnt out. https://www.dropbox.com/s/hsxsxy2let2er3a/image2.JPG?dl=0
In the second photo, if you draw a line through the resistor's length and you will hit a diode, that's the one that was replaced. The mainboard part# is epw65539. Am I wasting my time with this, should I just get a replacement? Having a hard time finding the part online, I am in Australia, but have yet to try to contact the manufacturer directly, its the weekend. Would prefer a speedy resolution ie repair as I have clothes to wash, but it may be easier for everyone if I just replace it outright. If anyone is familiar with this machine or has an idea of what might be going wrong please let me know.
Cheers
Mike
Cheers
Mike
