BOSE
Discussion in 'Electronic Repair' started by jim, Dec 25, 2006.
  1. jim
    jim Guest
    needing a fix for bose wave radio awr1-1w
    dead display , unit will not turn on ....... it has the voltages at the
    regulator .. thanks in advance for any help ......... Jim
    just a note . the display icons ALL lit up before failure
  2. Arfa Daily
    Arfa Daily Guest
    I've got the service manual, but you'll have to bear with me until after
    Xmas. Just as a matter of interest, I do work for a Bose service agent, and
    have done LOTS of these, but the symptoms you describe are not any that I
    have ever had. It sounds a bit system control micro-ish, but may not be. If
    you would like me to scan the relevant manual bits, mail me off-group, so I
    remember. Spares may turn out to be an issue, because they are *very* anal
    about who they will supply.
    Arfa
  3. Look for a bad 1 ohm flameproof resistor in the power supply, near a TO-220
    package regulator IIRC, around the middle area of the main board.
    MarkZ .
  4. Nate Scharff
    Nate Scharff Guest
    I think it needs a new 9 volt backup battery.
  5. PhattyMo
    PhattyMo Guest
    Now it's a _really_really_ overpriced piece of garbage.
  6. ChinaKid
    ChinaKid
    3
    Aug 7, 2009
    Wish to know if looking at Amplifier IC
    Hi Arfa,
    Am I looking at the right direction? My Bose Waveradio do not have sound.. I checked fuse, transformer, 7812 IC, most of the electrolytic capacitors, 10000uF cap - all OK.
    Input to the Amplifier IC is 13.5V to pin 3 and 13 - OK.
