Bosch WVT1260GB washer dryer not heating
Discussion in 'Troubleshooting and Repair' started by Martfoxy, Apr 25, 2013.
  1. Martfoxy
    Martfoxy
    54
    Apr 25, 2013
    I have checked all three thermostats and they conduct
    The element is about 34 ohms. There doesn't seem to be a
    Neutral return.
    I have checked the main pcb and there is a burnt
    Coil marked KA 03/05 063.783 it has 2 pins onside
    And 3 the other. I would like to replace it but not
    Sure what it is exactly. The 22uF 400v capacitor next to it
    Is ok I tested it on a meter and measures correct.
    Can anyone help?
  2. Martfoxy
    Martfoxy
    54
    Apr 25, 2013
    Photo of PCB
    photo showing burnt coil.
  3. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    Those 'coils' don't burn-up by themselves.
    Something else in your circuit caused this damage.
    Don't just replace the coil, or transformer, or whatever it is, without checking the
    rest of the circuit.
  4. sheldonstv
    sheldonstv
    68
    Jul 17, 2007
    give us a pic of the whole board-unless you know what you are doing this sort of repair would be better off with board replacement,depending on the type of board fitted the element is either relay switched or controlled via triacs on the board....the other thing that will cause it not to work is the thermistor located in the same housing as the heater element.Remove the heater element and connect it to 240v ac breifly to see if the element is ok,taking measurements with the leads connected is no test of element continuity
  5. Martfoxy
    Martfoxy
    54
    Apr 25, 2013
    Element heats
    Thanks for your reply. I tested the element on 240v and it does warm up. Also tested the three thermistors with the leads off and all conduct ok.
    I enclose pictures of the dryer board which also controls the motor which works ok. I tested all three relays and they seem to work ok - conduct on the 240v side when 12v is applied to the other side.
    It seems like the element is getting 240v but there is no neutral return - I read on one forum that it switches the neutral - not sure if this is correct.
    The 4 prong socket on the edge of the board feeds the 3 thermistors and the element. The two prong socket on the other side feeds the fan motor.
    Someone on a forum said they had the same no heat problem and swapped this dryer board and it didn't fix the problem so thought it must be the main board.
  6. Martfoxy
    Martfoxy
    54
    Apr 25, 2013
    dryer board photos
    Dryer board photos
  7. sheldonstv
    sheldonstv
    68
    Jul 17, 2007
    post the main board as well,it may be something as simple as a brconnection at the crimp connecting to the pcb or the element itself-lets have a pic of the machine etc element wise and the thermistors youve checked
  8. Martfoxy
    Martfoxy
    54
    Apr 25, 2013
    Working now
    It was a fault on the main board I sent off for repair.
