bootstrap analog multiplexer
Discussion in 'Electronic Design' started by gravpoet, Mar 15, 2007.
  1. gravpoet
    gravpoet Guest
    I need an analog multiplexer that can process ±40V DC voltage
    inputs...any ideas ?
    I've seen some info on bootstrapping of op amp supplies to get higher
    output voltages...I'm wondering if this technique or something similar
    can be applicable to to analog multiplexers ?
  2. Joerg
    Joerg Guest
    Nope, you just buy'em :)
    Supertex makes HV muxes:
    http://www.supertex.com/products/selector_guides/100
  3. gravpoet
    gravpoet Guest
    Thanks for your input.
    The mux is at the (+) input of an op amp configured as a voltage
    follower. My design requires 1GΩ of input impedance minimum which
    would preclude resistor type attenuators. I am assuming that is what
    you were referring to. I may have better luck looking for an accurate
    "active" attenuator (?).
    The Supertex devices in the previous post may be a good
    solution...I'll have to review the specs.
  4. There's also the possibility of using optically-switched
    MOSFET switches, some of these are quite good for signals.
    You mention a 1G Zin requirement, what about I_leakage
    and capacitive-loading specs, anything there?
    What are you working on?
  5. GravityPoet
    GravityPoet Guest
    This is an input circuit to a general purpose data acquisition board.
    The output of the analog multiplexer is buffered with a voltage
    follower (AD8512) in order to meet input requirements of 1GΩ input
    impedance and input leakage
    < 0.5µA.
    The output of the voltage follower then feeds a level shifter/
    attenuator ckt that differentially drives a 24-bit ADC.
    Thanks for the help.
