Boosting voltage of 2AA battery to power Luxeon LED
Discussion in 'Electronic Basics' started by Daniel Towner, Dec 5, 2003.
  1. Hi all,
    I'm making myself a head-torch using one of the new Luxeon LED's. At
    the moment I power it from a 9V cell, with a series resistor, but this
    obviously wastes a lot of power in the resistor. I've seen that some
    companies are manufacturing similar Luxeon torches which are powered
    from 2 AA batteries, using a voltage booster. How would I go about
    building such a circuit? Are there any components I can buy which
    would make the circuit simpler (e.g., IC's)?
    FYI, Luxeon LED's have a forward voltage of 3.42V and draw 350mA.
    thanks,
    dan.
  2. JeB
    JeB Guest
    would 3 batteries make life a lot easier?
  3. Was thinking of making one myself. With just a couple of components, I've
    tried to copy the circuitry similar to the Luxeon torches but gave up and
    used all kinds of available batteries from 3V to 1.5V watch Lithium
    batteries.
    Indi
  4. That will be my last resort. The argument I've seen against 3
    batteries + resistor is that such a setup is not as efficient.
    Boosting the voltage of 2 batteries is (so I'm told) more efficient
    than using more batteries and dissipating power through a resistor.
    Also, since you can only buy batteries in powers of 2, 3 is a strange
    number to use (though plenty of manufacturers make products which use
    3 batteries, presumably because that is cheaper than making a voltage
    booster).
    dan.
  5. Voltage boost regulators are not generally as efficient as voltage
    buck regulators. Use whatever number of cells provides a little more
    voltage than needed, and build an efficient buck switching current
    regulator for highest efficiency.
  6. Ian Stirling
    Ian Stirling Guest
    This is true.
    Does it matter though?
    If you are using rechargables, I would consider 3 NiMH AA cells.
    This is a better voltage match.
    These start at about 1.48V, when they are just off charge, and
    have voltage around 1.2V per cell for the majority of the cycle.
    The right way is to do a switch-mode power converter.
    This can have efficiancies over 90%.
    The easy way is probably to take three NiMH AA cells, one power transistor
    and a variable resistor, and a resistor of a tenth of the value of the
    variable one.
    Take the NPN power transistor, connect the base to the variable resistors
    wiper, and one leg to the resistor.
    Connect the resistor to the positive supply.
    Connect the emitter of the transistor to ground.
    The collector goes to the negative of the LED, and the positive of the LED
    is connected to the supply.
    The variable resistor is chosen so that it's about a third of
    (Vsupply(max) - 0.6) * Transistor Hfe * .35A.
    This is bad practice in general, as it's very sensitive to transistor
    Hfe, which can vary greatly.
    However, it provides a not-too-bad current source over the range of interest.
    Set the pot (with fresh batteries) so that it draws 350ma.
    It'll go down to around 3.4V (I forget the internal resistance of the luxeon
    star) or a bit lower.
    Anyone got a transistor suggestion?
    Efficiancy will be about 75-85%.
    The transistor will dissapate at most .4W or so with fresh alkaline batteries.
