Boost Garage Door Opener
Discussion in 'General Electronics Discussion' started by eaks77, Jan 15, 2014.
  1. (*steve*)
    25,360
    2,756
    If it used to have better range, it might be worth replacing the coax. There is a possibility that somehow water has entered the coax. Is the end attached to the antenna well sealed?
    I'll leave it to Davenn to comment on the design of the folded half dipole :)
    In any case, it's possibly directional with a bend in it like that. Does it exhibit more range in some directions than others? Is it possible to turn the antenna around so that maximum range corresponds to the direction you'll most often be in?
