Categories
Platforms
Content
I am using 3A boost converter to charge laptop from 12v acid battery, the laptop draws 3amp and the boost converter starts to burn out, what should i add to it to limit the current and protect my laptop?? Resistor capacitor diode???
actually the laptop needs at max 1 amp usually it needs 0.5 amp as i measure its original charger,
The label shows a 19.5VDC/2.31A adapter. It says 45W (19.5V X 2.31A) so the power and current must be when the battery is dead. Your ammeter has some resistance that reduces the current reading.
Either the boost converter cannot produce its rated 3A output without burning or its output voltage is too high causing the current to be too high.
A fuse will limit the current and protect your laptop.I am using 3A boost converter to charge laptop from 12v acid battery, the laptop draws 3amp and the boost converter starts to burn out, what should i add to it to limit the current and protect my laptop?? Resistor capacitor diode???
