H
Hammy
For anybody looking for an inexpensive way to check BW and PM of your
PSU's I came across a method using just a scope and signal generator.
The test procedure is outlined in the application note below from
National.
www.national.com/an/AN/AN-1889.pdf
I don't understand why FRA's in the Hz to maybe 2MHz range aren't
available for a reasonable price. You could buy a nice used truck for
what Venable wants for his?
I know the accuracy depends on your scope but it should give you a
good idea and you can always check with a pulse load test for BW.
National.
