Boat Lift VFD Controller
Discussion in 'Troubleshooting and Repair' started by Y2KEDDIE, Nov 8, 2012.
  1. Y2KEDDIE
    Y2KEDDIE
    259
    15
    Sep 23, 2012
    I have a Reinmann & Georger Corp., VL Direct Drive Compact Guard, Boat Lift Hoist.
    It uses a 3 phase 230VAC, 2.4A, 3/4HP motor and VFD drive circuitry.
    The circuitry experienced an overvoltage surge. It burned (charred) R1, a VDR (voltage dependent resistor). In its charred state the R1 (VDR) measures 10 ohms.
    The 110 VAC input is in series with R1 feeding the primary of a small ( 1” DIA. torroid, 16 ga wire, 13 turns 1:1) torroid transformer. The secondary feeds a bridge rectifier (GSIB2580).
    The bridge is replaced, but I need the value of R1. I think it may be only for surge, and maybe I can use a 10 resistor for testing. I would like to know what value VDR I should be using to complete the repair.
    Eddie
