BNC Cameras, What can I do with them?
N
Nasedo
I have 4 mini, BNC cameras that I received from work, after we upgraded
the security system. These camers have BNC connections. If I buy BNC
to RCA adapters, can I have them ran to my televison set? I am not
sure how BNC cams work. It looks as though it is simple coax cable.
Do the cameras not need a power source? Any suggestions and pointers
are appreciated.
F
Frank Olson
are appreciated.
If your television has a video in terminal (usually a RCA jack with a yellow
centre) then you should be able to hook the cameras up with a BNC to RCA
adapter and standard RCA cables. This won't work if the cameras derive
power through the BNC connnector, however. For those types of units, you'll
need the manufacturer's monitor at the "head end".
What make of camera are they? Are there screw type connections on a small
terminal block at the back of the units? If there are, is an input voltage
indicated?
R
Robert L Bass
are appreciated.
You can connect them (one at a time) to any TV that has a line level (yellow
RCA) jack. Just buy a BNC to RCA adaptor. You may be able to get the
adaptor at RatShak. If you want to view all cameras from a single TV you'll
need either a switcher (cheap) or a multiplexor (not cheap).
Regards,
Robert L Bass
Bass Home Electronics
2291 Pine View Circle
Sarasota · Florida · 34231
877-722-8900 Sales & Tech Support
http://www.bassburglaralarms.com
