Blue LEDs? when did that happen?
G
guy-jin
I ran across an old electronics book, the beginning chapters of which
deal with light emitting diodes. it described the problem of blue
LEDs; IIRC, the distance between the poles determines the color, but
when you get them far enough apart to make blue light, current no
longer flows between the poles.
Am I remembering correctly, and how was the problem solved?
C
CBarn24050
Must have been an old book, the problem was allways getting the right material
to make them, now we have UV leds as well. The Xray led is still a way offf yet
though.
A
Adam Aglionby
By one man Shuji Nakamura
http://www.businessweek.com/1999/99_24/b3633068.htm
Adam
B
Austin,
Many things have changed since you were frozen in the 60's. And yes,
Liberace was gay.
John Larkin
It's the semiconductor bandgap, not the physical dimensions, that
determines the color.
I think the Cree SiC blue led's predated these, but they were
horrendously inefficient: they needed something like 3 volts, 50 mA to
be a decent panel indicator. Paralleled 74S38s + 27 ohms from 5 volts!
But where do they use blue traffic lights?
John
W
Winfield Hill
John Larkin wrote...
The modern high-efficiency blue (and white) LEDs also require 3V, as
determined by the band-gap voltage like you said. But they give more
light at lower currents. These days all the rage is purple LEDs, for
a much much more impressive light-color sensation.
Isn't purple needed for low-rider under-the-car lighting?
B
Bullwinkle Jones
Japan, I think!
John Larkin
Every couple of years we have to write ECOs to change the
current-limit resistors on a lot of our products that use blue LEDs.
They keep getting more efficient, and customers complain that our
front-panel lights are blinding them. We must average about 5 mA these
days, down from 50 with the old Cree parts.
John
D
Don Bruder
John
Blue plus yellow equals green...
D
Don Bruder
John Larkin said:
Is that somehow better than using green?
Doubtful that it's "better", but... <shrug>
(And never mind the fact that I brain-farted on the fact that we've had
green LEDs seemingly forever - Was thinking in terms of "Damn... Only
have red and yellow - Gotta "build" green if using LEDs, and the only
way to do that is yellow plus blue.")
D
Don Klipstein
Ever mix the light from a blue LED with the light from a yellow one?
It's certainly not green.
- Don Klipstein ([email protected])
John Popelish
They cover too much of the visible spectrum to have any very saturated
color at all.
C
Christoph Loew
Don said:
Maybe this came from the Japanese having the same word for the colors
blue and blue-green - something that I heard is true.
That is so; in the Japanese Language a 'green' traffic light is called
'blue' ["ao";"aoi"] while e.g. a 'green' leaf is 'green'
["midori";"midori no"]. As a result, a green traffic light and a blue
LED are described by the same adjective which may be the source of this
confusion - especially since the actual color of the traffic lights is
identical to the western ones.
Chris
D
Don Bruder
Can't say I have. To be honest, I don't think I recall ever even having
a blue and a green LED in the same room together, let alone trying to
mix 'em.
G
Gordon Youd
I once had some LEDs which gave all the colours of the rainbow including
xray, I put them directly across the mains, WOW!!! I lost my cat the same
night.
Gordon.
Similar threads
Replies
3
Views
941
William Sommerwerck
W
A
Replies
Views
1K
Spehro Pefhany
S
C
Replies
Views
1K
cornytheclown
C
