Blow fuse
Discussion in 'Power Electronics' started by Robert Zulu, Apr 30, 2020.
  1. Robert Zulu
    Robert Zulu
    Apr 30, 2020
    Any who can assist,my old model tv keeps on blowing fuse.
  2. Hunter64
    Hunter64
    39
    12
    Nov 20, 2018
    Stop changing the fuse.
    davenn likes this.
  3. duke37
    duke37
    5,338
    753
    Jan 9, 2011
    A lamp limiter will let you get some voltage into the TV to do some investigation if the fuse is in the mains feed.
    Get a circuit diagram (top right) to help you on your way.
  4. bertus
    bertus Moderator
    541
    179
    Nov 8, 2019
    Hello,
    Without any information on brand and type it is very hard to say anything usefull.
    There must be something wrong with TV when it is blowing fuses.
    Bertus
  5. Robert Zulu
    Robert Zulu
    Apr 30, 2020
    The fuse is implanted and its non removable . Transformer can couse a fuse to blow?
  6. Bluejets
    Bluejets
    3,990
    824
    Oct 5, 2014
    Yes but it's not common to do so.
    If you use the series lamp as duke37 suggested, it will allow you to do some investigation without the fuse blowing.
    One I use here has an incandescent 100w flood lamp but just about any incandescent lamp will suffice.
    Method requires good knowledge of the dangers associated with mains level voltages so if you are not familiar with the workings, best to leave it to someone who does.
  7. dave9
    dave9
    881
    217
    Mar 5, 2017
    Your ability to solve this is directly related to the effort you put forth. So far, it doesn't seem like you are going to fix this.
  8. davenn
    davenn Moderator
    13,555
    1,853
    What do you mean by that ??
    you still haven't done as asked and supply make and model of this TV
    bertus likes this.
