T
tempus fugit
Hey all:
I have a TL071 on a single supply in a noninverting amp configuration, and
I'm trying to figure out some values for blocking caps. The voltage divider
is 2 22K resistors, and this is connected via a 10Meg resistor to the +
input. So for that cap there, do I use 10Meg as the value of R for
1/2*pi*f*R, or would I use 22K? My output is connected to the next stage via
a 100ohm resistor. Do I use that as the R value in the equation, or would I
use 47K (which is the input Z of the next stage)? My Ri is 3.9K, so from
this I figured I needed about 10-15uF, but i'm not sure about the other 2.
