Blender conversion into rc car
Discussion in 'General Electronics Discussion' started by Frndlystnr, Aug 10, 2016.
  1. Frndlystnr
    Frndlystnr
    3
    Aug 10, 2016
    So I'm gonna take a guess and say that I can convert a blender into an rc car. Sounds pretty straight forward if you think about it. Powerful motor in blender stripped down laid horizontally paired to pulley or something. i am open to any suggestions. Is this a good idea?
  2. Harald Kapp
    10,079
    2,153
    You'll need a veeeeeeeeeeeeeeeeeeeeeeeeeery long extension cord to power the ex blender motor...
    Have you considered using off-the-shelf RC components which ave been honed over the years to fit the purpose?
  3. Frndlystnr
    Frndlystnr
    3
    Aug 10, 2016
    My idea solder the blender motor to a power source like a battery that would sit on the rc
  4. Harald Kapp
    10,079
    2,153
    Afaik a blender motor is AC powered. You'll need a DC/AC converter with sufficient output voltage and power to operate the motor.
    A blender will need ~ 500 W (give or take some).
    Suppose you have a 12 V battery and an ideal converter (note that no ideal converter exists, add 10 %... 20 % losses for the converter). 500 W from 12 V means 42 A (rounded). You'll need a 14 Ah battery to run the car for 20 minutes.
    A brushles RC motor can be had at e.g. up to 700 W top power, will weigh less than the blender's motor and RC speed control is readily available.
    Plus all the other gear you'll need to control the RC car.
    Minus the risk of dealing with potentially lethal voltages as required by the blender motor.
  5. Frndlystnr
    Frndlystnr
    3
    Aug 10, 2016
    Good point but I am just interested in making it work not how effeciant it is
  6. davenn
    davenn Moderator
    13,598
    1,875
    you realise it will be a big and heavy battery ... eg a car battery ?
    what physical size did you expect your RC car to be ?
  7. Alec_t
    Alec_t
    2,844
    760
    Jul 7, 2015
    Others have pointed out the impracticalities, but if you're determined to use a blender motor post the spec of the motor (voltage/current/power/frequency ratings).
  8. BobK
    7,682
    1,686
    I think I will build an RC car with a steam engine. Does anybody know how large he water tank will have to be?
  9. Harald Kapp
    10,079
    2,153
    Why use water? Use liquid air, then you will not need an additional source of heat to generate 'steam'. The thermal energy from the ambient will suffice, provided your heat exchanger is big enough.
