I have a little EL wire project going, which I was rambling on about my 'I wish I could's.
I have a CL-ELI IPTC 9V to 3Khz inverter from Coolight.com that I can power wire with.
'I wish I could' not have to disconnect power for some momentary(like less than 2sec) load changes. An acquaintance casually mentioned why not use a bleeder resistor wired across the inverter leads on the 3Khz side before taking them out to the load, allowing me to simply quickly switch loads without frying the inverter. This sounds like a brilliant idea....if I had any idea how to calculate what Ohm resistor I would need for this.
My experience with electronics is firmly on the 'V' side and not the 'Khz' side, anyone want to give me a hand? Thanks in advance.
