BLDC VESC using DRV8301 and STM32
Discussion in 'Microcontrollers, Programming and IoT' started by Kranthi, May 7, 2021.
  1. Kranthi
    Kranthi
    Sep 15, 2017
    Hello everyone,
    I have built a hardware similar to VESC by Benjamin Vedder. I have also attached the screenshots of the schematic built. I'm using STm32Cube ide to code.
    Below is a simple code I have written to check for the output on one phase. I'm able to see the PWM on an Oscilloscope from the MCU. But I'm unable to see any output on the drv8301 outputs. Is there any configuration to be set on drv8301 to generate the outputs. please suggest
    I'm using a Power supply and have gone upto 20V on V_supply
    PWM on highside mosfet H1-PA8
    On on lowside mosftet L2-PB14
    EN_GATE-PB5
    HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
    while (1)
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);
    TIM1->CCR1 = 50000;
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_14, GPIO_PIN_SET);
      File size:
      145 KB
      5
      File size:
      163.5 KB
      4
