Blaupunkt Finish line 320 car radio setup
D
Doug King
Hi does anyone have the instructions to input the code protection number
on the above or any similar radio from the Blaupunkt range?
I have the code and can get the first digit to display 1 with the other
3 zeros but it is either or 1 or blank? I need to display a 2 in the
first position.
Thanks for any help
Jeff
Using presets 1 thru 4, push preset 1 again to move the
first digit up one, then go to the next preset and press it
as many times as needed to get to the next number....
After you have the code displayed correctly there is
another step either press preset 5 or seek up, or ?
depends on model and I have not seen that one.
Jeff
D
Doug King
Thanks Jeff, I have sorted it now it seems the first digit is blank of
1, blank is equal to '0' so in the past it must have been reprogramed to
give only 2 options for the first digit in my case it is ''0' Then it
was seek up, it work fine now!
Doug
