P
Phil Allison
** Hi to all,
the dreaded " Yellow Glue" problem has been mentioned here a few times.
I have exactly the same problem, but the glue is now black instead - with a
KRK 'Rokit 5" powered monitor - from China of course. Both PCBs are
liberally covered in the stuff, more on the amplifier and PSU one.
Symptoms in my example were loud crackling and low volume - which
recovered when I wound the AC back to 160V !!
Seems you have to get every bit of it off to effect repair. Along the way
you will see corroded leads and PCB link wires - there is a 2.2kohm next
to the filter caps that is buried in the glue and needs replacing.
This is worse than the Yellow Glue problem as it becomes conductive in areas
that have no heat.
Could the black colouring be carbon ??
.... Phil
that have no heat.
.... Phil
