John Gilmer
Hi:
I STRONGLY suspect that the "Blower Motor Control Module" (AC/Delco
#15-71971 for those who want to "look it up") is no more. (It has failed
in the "full on" mode.)
The shot manual describes it as containing an amplifier and driver circuit.
It's "transfer" characteristics are:
Input range: 2.5 volts to 7 volts for a motor voltage (which feeds back to
the HVAC control system) for an output range: 4 to 12 volts respectively.
It just has four terminals: battery, ground, input from control system, and
motor drive (other terminal of motor is ground). It's protected by a 30amp
fuse.
I debating whether to just take the car into a repair shop, get a "generic"
replacement (which will have to be jury wired in and will cost $50+ from
NAPA), try for the OEM part-new or used; or jury rig with Radio Shack parts.
Anyway, an thoughts on what's in it? (Remember, 2.5 to 7 volts IN and 4 to
12 volts OUT.)
EMWTK
Oh, for those who like to second/third guess, it's from a 1994 Buick
Roadmaster.
fuse.
12 volts OUT.)
EMWTK
Roadmaster.
