BJT - understanding its operation
Discussion in 'Electronic Basics' started by Seeker, Mar 15, 2006.
  1. Seeker
    Seeker Guest
    I'm an electric engineering student. I'm getting into electronics and I
    can't figure out the bjt transistor.
    The fact that it has two p-n contacts means that I'm confused every time I
    see a schematic. Of course the book I'm reading does a pretty good job of
    explaining but I still can't figure it out.
    For example:
    http://img518.imageshack.us/img518/7008/screenshotlineartechnologyltsp.png
    This is a circuit I took from the book, it says it's used for sampling.
    When V1=0 => Vo=Vi=V2
    and when V1=5=>Vo=0,2V
    V1 is generally a pulse signal generator and V2 is the signal we want to
    sample. I understand that the bjt is used here as a switch, it operates at
    core or cut-off mode etc.
    What I don't understand is, isn't the V2 source affecting the circuit? We
    control the Ib current with the V1 generator but why doesn't the V2 signal
    affect our circuit whatsoever?
    I can learn the circuits and study them on SwCAD but I don't want to have
    to refer to a book everytime I see a new circuit so I can understand how
    it works. Any help would be appreciated.
  2. V2 is the dc power supply.
  3. I'm still learning about more general models, myself.
    Well, they don't show one of them. But it's there. It's just usually
    not symmetrically built, so reversing the emitter and collector leads
    won't get you the same behavior. It's supposed to go in one way. But
    I understand that there are rare times when you might prefer to
    reverse it and use it the other way. Not that I've done so for any
    design purpose, though.
    It's good to hear that the book is okay.
    It does. It affects the voltage seen at the collector when the BJT is
    "off" and there is effectively no Ib current. However, when the Ib
    current is active and substantially driving the BJT into saturation,
    the collector will be close to or less than a single diode drop above
    the emitter. This is because, in saturation, the base-collector diode
    is generally no longer reverse-biased and is starting to conduct in
    the forward direction. Whatever collector current is required to
    reach that point will flow, assuming the BJT's base drive is
    sufficient and maintained.
    How that takes place is another story. You might take a look at John
    Popelish's recent contribution here to a thread titled, "transistors:
    so confusing!!" on his 'drunken bum on a crazy street' theory.
    Jon
  4. We
    Yes it is. It certainly affects the current flowing out the emitter.
    Like I said, it does.
    Look at it like this: V1 will cause 5mA to flow thru Rb, into the base
    and subsequently out the emitter to ground. Rc will allow up to 100mA
    to flow thru it and into the collector and out the emitter to ground
    (assuming no current is being drawn from Vo). As long as the DC beta
    (Hfe) is at least 20, a 5V pulse from V1 will cause the transistor to
    turn on and shunt all current available from V2 to ground. This has the
    measurable effect of lowering the voltage at Vo to something very close
    to ground (0.2V in your case). You should think of the BJT transistor
    in terms of current and not voltages as that's what it is all about.
    Transistors amplify the current applied to base by the beta of the
    transistor and will allow that amount of current to flow thru the
    collector. Something like a water valve allows you to apply a small
    amount of force to regulate a much larger force.
    Sorry if it's not a very clear explanation. I'm sure others will do
    much better. :)
  5. kell
    kell Guest
    For example:
    Yes indeed, that's about all you need to know to figure out how this
    circuit works. Never mind about the internal pn stuff.
    V1 controls the transistor. So with V1 high, the transistor on, the
    transistor grounds out the node where you see Rc, the collector, and Vo
    all connected and thus you see essentially zero volts (actually 0.2) at
    Vo.
    Now put V1 low. That turns the transistor off. Now with the
    transistor's collector/emitter terminals looking like an open circuit,
    the voltage at Vo equals V2 and Vi (why did they label it twice?), and
    you have your sample. This assumes that whatever you are using to
    detect the voltage at Vo has a high impedance, so it doesn't affect
    things by loading down the circuit.
    You could build this circuit on a breadboard. Connect voltmeter leads
    to Vo and ground. This is your sample detector. Use a switch to turn
    the 5 volts on and off (the circuit drawing omitted that part). Use
    some low voltage at V2, like a twelve volt battery. The voltage on
    your meter's screen will either equal V2 or read very low (just a few
    tenths of a volt), depending on what's going on at the transistor's
    base.
  6. Jamie
    Jamie Guest
    V0 is what you want to sample.
  7. redbelly
    redbelly Guest
    Here's a link to John's drunken-bum description:
    http://groups.google.com/group/sci....ken+street+transistor&rnum=1#5105f814d61a9ba5
    One thing I didn't realize, until many years had passed, is that the
    emitter has much higher doping than the other junctions, so nearly all
    the current in a transistor is from charges that originate in the
    emitter.
    Mark
