bizarre
Discussion in 'Electronic Design' started by John Larkin, Sep 29, 2004.
  1. John Larkin
    John Larkin Guest
    Well, the Harvard architecture, the 64-byte address space, the
    hardwired subroutines, and the single instruction, to start.
    John
  2. Guy Macon
    Guy Macon Guest
  3. john jardine
    john jardine Guest
  4. Jeroen
    Jeroen Guest
    Bizarre because it's optimized for a high(er) level language other then C?
  5. Rich Grise
    Rich Grise Guest
    I'm still wondering what a "64-byte address space" is. Doesn't sound
    like a heck of a lot! ;-)
    Cheers!
    Rich
  6. Guy Macon
    Guy Macon Guest
    It's a proceesor that runs Forth as it's assembly language.
    Why would anyone want to store anything in a cruddy old address
    space when they have a modern efficient stack to store things on? :)
  7. Rich Grise
    Rich Grise Guest
    You've got either an extraneous apostrophe here, or a missing
    comma: "It's a processor that runs Forth, as it is assembly language."
    Some guy tried to explain RPN to me one time - he says, "How do
    you do it on paper? You write down 3, then you write down 4, then
    you add." I tried patiently to explain to him. "I don't want to
    write them down. That's why I use the machine. I want to know what
    3 plus 4 equals. So I press 3, plus, 4, equals, and there's the
    answer." "But you don't write down 3, then add, then write down 4!"
    "No, I don't add at all. The machine does." "But - but - but ..."
    He just didn't get it. ;-)
    Cheers!
    Rich
  8. Al Borowski
    Al Borowski Guest
    One of my favourite examples (copied from an earlier post of mine) is
    Suppose you have 4,5 and 6 ohm resistors in parallel. In series with
    them you have a 7 ohm resistor. In parallel with *that* arrangement you
    have an 8 ohm resistor. Whats the equiv resistance?
    0----------------------------------
    |7| |
    -------|------- |8|
    |4| |5| |6| |
    0-------------|-------------------|
    Of course, for the sake of the argument, the values are nice and even,
    and easy to work out without a calculator. This is a fairly simple
    circuit as well.
    Algebraic entry solution:
    1/( 1/8 + 1 / (7 + 1 / ( 1/4 + 1/5 + 1/6 ) ) ) =
    ~30 keystrokes, and a bit of a pain to keep the brackets matched.
    RPN solution (with comments, because its a PITA to read, but easy to
    enter IMO)
    # means the '1/X' key.
    first find the equiv resistance of the 4,5,6 ohm part.
    [ 4 # 5 # 6 # + + # ] (find the inverses of 4,5 and 6, adds them and
    inverts the resul)
    then add the 7 ohm resistor in series
    [ 7 + ]
    then place the 8 ohm resistor in parallel with the resistance so far
    [ # 8 # + #] (again, find the inverse of the answer so far, find the
    inverse of 8, add them, find the inverse of that)
    ~16 keystrokes
    This look terrible to read on a PC screen, but is shown graphically as
    you type it - you can follow the working easily if you do it on a
    graphics calc. After the first part the screen would show (1/
    (1/4+1/5+1/6) in textbook form for instance.
    cheers,
    Al
