I once found some 2SC2878's in some junk. Vcbo = 50V, Vebo = 25V, Ic =
300mA, forward hFE 200~1200, reverse hFE 150 typical. Good luck finding
more, though.
Tim
Deep Friar: a very philosophical monk.
Website:
http://webpages.charter.net/dawill/tmoranwms
Got just two nice lab psu (100W and weight only 13 kg) off Ebay.
So to put them in some use I measured how well some bipolars work
with collector and emitter swapped.
http://koti.mbnet.fi/hsahko/trans/
-ek
One of the problems with using "regular" transistors in the inverted
connection is that the applied voltage between "collector" (really the
emitter) and base is limited to about 7V, the Vbeo rating of the
transistor. Texas instruments used to make a line of PNP transistors
that were symmetrical in that the forward and inverse betas were
equal, and the Vbeo and Vceo ratings were equal. They were designed
for chopper applications. I'm not sure that they are still available,
since FETs are far superior in this application.
